ACS upgrade
Jagdeep Gambhir Wed, 10/10/2007 - 04:48
Before you start upgrade make sure you have most recent backup from acs.
Now you need to upgrade it to 3.3.3 by running setup.exe. During that process it will give you option "keep existing database" make sure you enable it else all data would be lost.
Same procedure is to be used for upgrading it to 4.x.
