10-10-2007 02:11 AM - edited 03-15-2019 06:54 AM
Any body knows what new feature in Call manager 6 differs than 4.2
10-10-2007 03:43 AM
Hi Wesamtaher,
I hope this answers your question. Bear in mind that major release changes and added features are introduced onto the next realease. So for example you have to go from 4.0 to 5.0 first to check for differences, and then from 5.0 to 6.0. I trust this make sense to you.
CCM 4.2.x New Features
CCM 5.0.1 New and changed Information
CCM 6.0.1 New and changed Information
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_0_1/601cmrn.html#wp44146
The following URL may also prove useful:
<http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_software_versions_comparison.html>
best regards
Ajaz
pls rate this post if you found it helpful.
10-10-2007 06:47 AM
providing a rate for any particular post is extremely helpful since it means that although one does not gain any monetary value from spending the time to reply - there is an element of satisfaction and confidence that can be attained. Those who do rate posts fairly and squarely are more likely to be assisted in the future with any issue. However, I personally am not willing to entertain any qtns from individuals who are not prepared to show their gratitude by way of rating useful replies, whether they be a fair reflection or unfairly reflected ratings!
thank you
Ajaz
