Frame-Relay over Ethernet
Oct 10th, 2007
Dear All,
I am looking for running Frame-Relay encapsulation over 10BaseT or 100BaseT port or Ethernet /Fastethernet port. I understand that the default encapsulation comes as ARPA since it works on CSMA/CD protocol.
Is there any possiblity to use Frame-Relay over Ethernet WAN link.
Overall Rating: 5 (1 ratings)
frank.murray Wed, 10/10/2007 - 08:34
no- they are both layer 2 protocols. Frame Relay only runs on serial interfaces.
paolo bevilacqua Wed, 10/10/2007 - 09:14
  • Hall of Fame,
    Founding Member
You can do FR switching over a GRE tunnel, so yes, you can transport FR on any media.
Remember to set IP MTU correctly when using GRE tunnels!
gaurav_thapar79 Wed, 10/10/2007 - 10:50
Thanx for your inputs. Let me simulate this concept and share my observation.
gaurav_thapar79 Wed, 10/10/2007 - 22:45
Please share the possible config to do the Frame-Relay encapsulation on Ethernet Lastmile with DLCI no. on GRE Tunnel.
paolo bevilacqua Thu, 10/11/2007 - 05:02
  • Hall of Fame,
    Founding Member
frame-relay switching
interface serial x/y
frame-relay route tunnel Z
This requires advanced ip service image, in the past required enterprise image.
As a recognition to those providing answers, please rate useful posts using the scrollbox below!
gaurav_thapar79 Thu, 10/11/2007 - 05:40
Thanx for your inputs and would surely rate your post. My requirement was completely different as the way have you interpreted.
1. I donot have serial connection.
2. I want to use Frame-Relay encapsulation.
3. I have ethernet 10Mbps WAN link.
Now please share your comments incase i can use Frame-Relay over Ethernet.
mheusing Thu, 10/11/2007 - 05:56
  • Cisco Employee,
Why would you want to use Frame-Relay? What is your underlying problem you want to solve using FR over Ethernet?
Seems more information is needed to find some answers useful to you.
Regards, Martin
