Multicast traffic UDP 239.1.1.1
Oct 10th, 2007
I have two call manager servers in the voice VLAN of 10.100.10.0/16
We have our normal servers in data VLAN of 10.10.10.0/24.
I am seeing a huge amount of UDP traffic when sniffing in promiscuous mode on one of the Data servers.
According to the Voice consultants that configured the network, this is normal and is just the MOH traffic.
But, should I be seeing this traffic on my data server is a different VLAN?
Overall Rating: 5 (1 ratings)
AJAZ NAWAZ Wed, 10/10/2007 - 05:52
  • Silver, 250 points or more
Is your network configured to handle multicast traffic?
Ajaz
wilson_1234_2 Wed, 10/10/2007 - 07:13
The server vlan is configured as such in the core switch where the devices are linked:
ip pim dense-mode
ip multicast ttl-threshold 2
ip route-cache flow
ip igmp join-group 230.0.0.1
ip igmp join-group 230.0.0.2
I see the same config in the workstation VLAN, but I do not see that multicast traffic on that VLAN.
also see this:
ip cef load-sharing algorithm original
ip multicast-routing
no ip igmp snooping
ip tcp path-mtu-discovery
no ip domain-lookup
ipv6 mfib hardware-switching replication-mode ingress
mls ip multicast flow-stat-timer 9
no mls flow ip
no mls flow ipv6
mls qos map cos-dscp 0 8 16 24 32 46 48 54
mls qos
no mls acl tcam share-global
mls cef error action freeze
I just talked with the Voice guy and he said multicasts are like broadcasts but can trverse layer 3.
I think as you said the network has to be configured to allow that correct?
I see nothing configured in the Voice vlan and the multicasts are on 239.1.1.1, not 230.0.0.1 or 2
wilson_1234_2 Thu, 10/11/2007 - 08:12
What I mean by a huge amount is that using wireshark and doing a packet capture, that is all I see on the interface.
In a matter 30 seconds there are 10,000 pakets all udp sourced from the Call Manager server.
It is non stop.
