CCM 4.1.3 service release question
I have two Callmanager Servers which need to be ugraded.The currect version is 4.1.3 SR1 on both of the servers.
i checked on the voice section of the download page what is the most up to date SR and i am a bit confused now.
What is the difference between "Multi-Fix Patch" and "Maintenance Upgrade"?
I see there is SR2 Maintenance Upgrade and SR5d which is Multi-fix patch.
Which one should i use?
pklos Wed, 10/10/2007 - 05:50
You should use sr5d. Patches are cumulative.
