Cisco 877 & 837 doesn't have IP nbar option
Oct 10th, 2007
Apparently the Cisco 877 and 837 routers should have the IP nbar option an an interface. Mine don't. The readme for Netflow says:
Platforms & Cisco IOS Versions that currently support CISCO-NBAR-PROTOCOL-DISCOVERY-MIB are
Cisco 1700 Series Router since Release 12.2(2)T
Cisco 2600, 3600, 7100, 7200 Series Routers since Release 12.1(5)T
Cisco 3700 and 7500 Series Routers since Release 12.2(8)T
The following Platforms also support NBAR:
Cisco 800 Series Routers
Cisco 1800 Series Integrated Services Routers
Cisco 2600XM Series Router
Cisco 2800 Series Integrated Services Routers
Cisco 3700 Series Multiservice Access Routers
Cisco 3800 Series Integrated Services Routers
Cisco 7300 Series Routers
Cisco 7400 Series Routers
Catalyst 6500 Family Switch with a FlexWAN card.
whiteford Wed, 10/10/2007 - 11:47
The 837 is 12.4(5b)
The 877 I can't get to at the moment, I know a 2006 IOS think Nov.
whiteford Thu, 10/11/2007 - 10:45
Not near the router, but I can tell you it's c870-advsecurityk9-mz.124-15.T1
Edison Ortiz Fri, 10/12/2007 - 10:05
You need advanced ip services, you only have advanced security.
This is the image you need:
whiteford Fri, 10/12/2007 - 10:13
Great, will my current config be ok after I upgrade? As I have a VPN setup on the config.
whiteford Fri, 10/12/2007 - 10:23
Thanks, fman my blackberry can't use that link. The nbar option apparently let's me get better stats on NetFlow.
