CSS - AVS implementation with SSL
Oct 10th, 2007
We are trying to design a solution with 2x CSSs 11501 and 2x AVS3120. The requirement is all the way SSL and cookie stickiness. Also, CSS will have to do URL rewriting from http to https.Is there a samle configuration for this kind of configuration? Will the CSS have to terminate SSL from client to AVS and then re-encrypt, terminate SSL from AVS to server and vice versa?
