How to log VPN connections to PIX 515E
Oct 10th, 2007
I've got a PIX 515E with PIX Firewall Version 6.3(3). For the moment, I've setup a group VPN.
What I'd like to do is to log every VPN connection to this PIX.
I've setup a syslogd. Trap level is set to informational. But with this level, I've got too many informations! And that generates more than 30MB of data everyday!
I know I need to narrow down on the messages, but I don't know what syslog ID's to use in order to know the connections (and probably disconnections as well).
Could somebody help me?
Danilo Dy Wed, 10/10/2007 - 07:40
  • Blue, 1500 points or more
I use Kiwi Syslog, use it for both PIX/IPSec and ASA/SSL-WebVPN. You can setup the PIX to send all logs from level 0 to 6 but in Kiwi Syslog, configure it to receive only "Authentication"
File + Setup + Rules + Add Rule
Rule Name: MyVPN
File + Setup + Rules + MyVPN + Filters + Add filter
Filter Name: MyVPN-AUTH
File + Setup + Rules + MyVPN + Filters + MyVPN-AUTH
Field: Message text
Filter Type: Simple
Include: "Authentication"
File + Setup + Rules + MyVPN + Actions + Add action
Action Name: Display
Action: Display
Display number: Display 00 (Default)
Action Name: Log to file
Action: Log to file
Path and file name of logfile: your path and filename
Log file format: choose your format
In the logs, you will see the following;
User name
User group
Source IP Address
Authentication: Successful or Rejected and Session type
Good luck!
Dandy
fmt_cisco Fri, 10/12/2007 - 09:13
I've tried exactly as you suggested, but I got nothing: no log is received!
I'm using group VPN. Is that the cause?
