Having trouble getting a very simple site-to-site VPN going
Oct 10th, 2007
The headend is an ASA5510 running 7.2(2).
I will post the config if requested, but here is the gist of it:
I have a nat exempt ACL and a corresponding nat 0 statement
I have an identical acl for the crypto map
I have sysopt connection permit-vpn
I have an appropriate transform set
I have a crypto map defined and applied. (includes a dynmap for remote users, dynmap is seq 99, site-to-site is seq 10)
I have isakmp enable outside
I have appropriate isakmp policies defined.
I have a tunnel group with the IP address of the peer defined and the shared key defined.
I have done numerous clear xlates and clear ipsec/isakmp sa.
When interesting traffic arrives at the interface, a debug crypto isakmp or ipsec shows no activity.
A packet trace runs and succeeds until:
Phase: 8
Type: VPN
Subtype: encrypt
Result: DROP
Config:
Additional Information:
Forward Flow based lookup yields rule:
out id=0x45c8ec0, priority=70, domain=encrypt, deny=false
hits=1, user_data=0x0, cs_id=0x3c4c550, reverse, flags=0x0, protocol=0
src ip=192.168.0.14, mask=255.255.255.255, port=0
dst ip=192.168.10.0, mask=255.255.255.0, port=0
Result:
input-interface: alarms-dmz
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
I am stumped, I've done this 100 times and this one is killing me. Random thoughts:
I've cleared the service policies I had applied
I've cleared the default group policy.
The "interesting" traffic in this case originates on a "DMZ" interface. I've tried security 100 and 80. The interface has no ACLs applied to it in either direction.
Any ideas??
acomiskey Wed, 10/10/2007 - 08:22
  • Green, 3000 points or more
Probably want to post the clean configs. One quick thought is that your nat exemption might look like nat (inside) 0 instead of nat (dmz) 0, just a guess of course.
mattward6 Wed, 10/10/2007 - 08:32
Thanks for the reply! The NAT statement references the correct interface, but a good guess. Here is what I think is the salient part of the configuration:
access-list alarms-no-nat extend permit ip host 192.168.0.14 192.168.10.0 255.255.255.0
access-list telsa extend permit ip host 192.168.0.14 192.168.10.0 255.255.255.0
nat (alarms-dmz) 0 access-list alarms-no-nat
crypto ipsec transform-set site-to-site esp-aes-256 esp-sha-hmac
crypto map melford 10 match address telsa
crypto map melford 10 set peer 75.148.20.165
crypto map melford 10 set transform-set site-to-site
crypto map melford 99 ipsec-isakmp dynamic dynmap
crypto map melford interface outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption aes-256
isakmp policy 10 hash sha
isakmp policy 10 group 5
isakmp policy 10 lifetime 86400
isakmp policy 65535 authentication pre-share
isakmp policy 65535 encryption 3des
isakmp policy 65535 hash sha
isakmp policy 65535 group 2
isakmp policy 65535 lifetime 86400
tunnel-group 75.148.20.165 type ipsec-l2l
tunnel-group 75.148.20.165 ipsec-attributes
pre-shared-key [redacted]
exit
clear xlate
**clear ipsec sa
**clear isakmp sa
I stumbled across a page that states the packet tracer won't work if the SA is not already established, so I guess that is not a valid test.
