Basic config for a Cisco 877?
Answered Question
Oct 10th, 2007
I have a Cisco 877 ADSL, does anyone have a basic config I can work from to get the internet work from this Cisco 877 ADSL.
I have just added the an 837 config and change Ethernet0 to Vlan1 and it doesn't work
Correct Answer by paolo bevilacqua about 9 years 6 months ago
You are very welcome. Please do not forget to rate useful posts using the scrollbox below!
Overall Rating: 4 (1 ratings)
paolo bevilacqua Wed, 10/10/2007 - 09:17
  • Hall of Fame,
    Founding Member
If you pasted the config over default, atm0 can be still shutdown. This is one thing to look for. After no shut and you check atm0, does it comes up ?
whiteford Wed, 10/10/2007 - 09:28
Hi, I already had a no shutdown in there, the atm 0 goes up then down and keeps doing this. If I do debug ppp negotiate and and authenticate then I get all zeros. Am I silly to think an 837 config should work on an 877? The only difference I can see between the 2 is the 837 uses ethernet 0 and the 877 vlan 1. The 837 works fine on the same ADSL line.
paolo bevilacqua Wed, 10/10/2007 - 12:12
  • Hall of Fame,
    Founding Member
You may need newer ADSL FW, either upgrade IOS to very latest T, or load the ADSL FW alone. For the latter access:
ftp://ftp.cisco.com/pub/access/800
The FW you want is 3.0.10 or 3.0.33. Check the readme for installation instructions.
whiteford Wed, 10/10/2007 - 12:26
If like to try the ios upgrade first, but there are so many, thing the current one is the advanced security, do you the latest version number for this?
whiteford Wed, 10/10/2007 - 23:20
Router>
Router>
Router#sh ver
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(4)T7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 29-Nov-06 00:43 by kellythw
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Router uptime is 1 minute
System image file is "flash:c870-advsecurityk9-mz.124-4.T7.bin"
paolo bevilacqua Thu, 10/11/2007 - 05:04
  • Hall of Fame,
    Founding Member
As indicate in the link above, you need either to upgrade to a minimum of 12.4(6)T, or use the separate ADSL firmware.
As a recognition to those providing answers, please rate useful posts using the scrollbox below!
whiteford Thu, 10/11/2007 - 05:13
I installed c870-advsecurityk9-mz.124-15.T1 and the router seems so much better. The version I was using had so many serious bugs. I will add the VPN stuff next and see how it goes.
Correct Answer
paolo bevilacqua Thu, 10/11/2007 - 05:14
  • Hall of Fame,
    Founding Member
