Easy Secure SOHO Phone Deployment
Oct 10th, 2007
We're looking for the easiest way to deploy an IP phone to home offices without the need for VPN. Essentially we want to deploy a phone with a static entry for TFTP to a public ip for the phone to register and rely on secure media and registration to secure the phone communication. This would effectively remove the need for a costly VPN SOHO router and lengthly config time.
hadbou Tue, 10/16/2007 - 12:38
  • Bronze, 100 points or more
You can use CME Deployment, 1700 sereis router will work with Cisco IOS Software Release 12.2(8)T or later with a minimum of IP Plus (IP/VOX Plus on the Cisco 1700 series) feature set.
