Hi Paul,
RF groups and mobility groups are similar in that they both define clusters of controllers, but they are different in terms of their use.
These two concepts are often confused because the mobility group name and RF group name are configured to be the same in the Startup Wizard. Most of the time, all of the controllers in an RF group are also in the same mobility group and vice versa. However, an RF group facilitates scalable, system-wide dynamic RF management while a mobility group facilitates scalable, system-wide mobility and controller redundancy.
So it is not necessary to have same mobility group name as RF Group name.
RF Groups are clusters of controllers who not only share the same RF Group Name, but whose APs hear each other. AP logical collocation, and thus controller RF Grouping, is determined by APs receiving other APs? Neighbor Messages.
So if your WLCs on different site have APs which cannot see each other there is no use to keep the 2 controllers in same RF group.
May be these links can help you with something
http://www.cisco.com/en/US/docs/wireless/controller/4.1/configuration/guide/c41rrm.html
A very good link for RRM
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072c759.shtml
Ankur
*Pls rate all helpfull post
