acs4.1 end user interface
Answered Question
Oct 10th, 2007
Hi all,
Currently, end users are prompted for authentication when they try to access the internet for username/password.
Is there any way to set the idle timer to a specific time? Per user or Per ACS Grouping?
Example: The user has been idle on that web session to any website for say 5 mins the session is timed out and they need to be reauthenticated through the ACS.
Correct Answer by Jagdeep Gambhir about 9 years 4 months ago
Under the IETF Radius Attributes section, You need to set radius attribute 28
Idle-Timeout:attribute 28
You will have to enter the time in Seconds
~JG
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Wed, 10/10/2007 - 17:10
~JG
