Major Problem with DCR and RME
Oct 10th, 2007
After I have imported the devices I saved to a file prior to moving to LMS 3.0 i'm having a hard time with trying to get RME to add devices to inventory and recognize that new devices are there to add to the archive. Should I post my problem here or open up a Tacas Request.
ebreniz Tue, 10/16/2007 - 13:57
  • Silver, 250 points or more
If earlier the devices were automatically detected and added then you can do this time also by running device discovery. Else you can add the devices manually to the RME database. you can also import the devices to RME database by exporting them from LMS to some file and then importing them to RME.
