DMZ network to internal network
I have read several posts on this and I still don't quite understand what needs to happen. I have a web server in the dmz (10.10.30.10) that needs to access a SQL server on the internal network (192.160.0.7). How do I allow this access. I currently can access the DMZ from any computer on the internal network. I have attached a sanitized copy of my config so you can see what I am doing.
sundar.palaniappan Wed, 10/10/2007 - 18:59
  • Green, 3000 points or more
static (inside,DMZ) 10.10.30.49 192.168.0.7 netmask 255.255.255.255
access-list DMZ_access_in extended permit ip host 10.10.30.10 host 192.160.0.7
access-group DMZ_access_in in interface DMZ
In addition make sure the firewall has a route to 192.160.0.7 via the Inside interface. I have assumed you aren't using this address 10.10.30.49 on the DMZ if you are then substitute that address in the static and ACL.
Sundar
sundar.palaniappan Wed, 10/10/2007 - 19:09
oops there was a typo in the IP in my last post. Here's the correct syntax.
static (inside,DMZ) 10.10.30.49 192.160.0.7 netmask 255.255.255.255
