The PC Disconnects Very often....
Oct 10th, 2007
The Situation is i have done Wireless bridging to provide Internet access to users in first floor. so the wireless bridge is a Cisco 1231 configured as a bridge, and in first floor is a same model 1231 acting as an AP.. the problem in with PC's connected as they frequently Disconnects from the AP...n Reconnects. The Antenna is in LOS with the PC's wireless LAN card and coverage is excellent, The PC's gets ip address from an ADSL modem connected to the Wireless Bridge. Any explanation on y it happens so ? The connectivity is like this.
[ADSL]-----[AWB] )))) ((((([Cisco AP]))))((( [PC]
ericgarnel Thu, 10/11/2007 - 07:21
  • Gold, 750 points or more
What is the OS on the laptops?
What wireless NICs are on the laptops & have you tried updating the drivers?
Also, Have you monitored the connection between the APs to see if it is dropping? and/or measured for interference?
vinupeter_19 Fri, 10/12/2007 - 11:51
Thanks alot it worked....the problem was occuring because the antenna of the PC Wireless card was broken..... banged my head to find the cause..... :-)
