SVI
ankbhasi Wed, 10/10/2007 - 20:51
Hi Aksher,
You create SVI on a layer 3 interface which acts like a default gateway /layer 3 interface for your clients which are in that particular vlan.
Because they are logical interfaces and do not have any physical interface you have to bind that vlan at layer 2 to some physical interface also but that is just a layer 2 binding and then you ca nconnect your end machine to that physical interface and define its gateway address as ip address you configured for that layer 3 SVI.
Ankur
*Pls rate all helpfull post
ilnaiduccna Wed, 10/10/2007 - 21:37
Hi Ankur,
Good your explicate It may not be a good diverse.
But I have doubt how to create SVI what are steps and the commands shall we use can u provide that few steps and commands it will great appreciated.
Regares,
Naidu.
ankbhasi Wed, 10/10/2007 - 21:48
Hi Naidu,
To create a layer 3 interface
Switch(config)#interface vlan
Switch(config-if)#ip address x.x.x.x
You can use the same command with different vlan number and subnet address for multiple SVIs.
Ankur
ilnaiduccna Wed, 10/10/2007 - 22:24
Hi Ankur,
Well your early and clear reply.
For ever and a day thanks for your participation in this forum and I am seeing your posts giving lot of information and those are had clear information.
Nadidu.
ankbhasi Wed, 10/10/2007 - 22:55
Hi Naidu,
Thanks for your comments and ratings. Keep participating in this forum.
Ankur
