self test...odbc+snmp fails
when i run self test, i get following..
PASS backup.pl
PASS database.pl
PASS mem.exe
PASS network.pl
FAIL odbc.pl
PASS platform.pl
FAIL snmp.pl
odbc.pl
FAIL
C:\WINNT\system32\odbccp32.dll FileVersion : 3.520.6307.0
C:\WINNT\system32\odbccp32.cpl FileVersion : 3.520.6200.0
C:\WINNT\system32\odbcad32.exe FileVersion : 3.520.6200.0
C:\WINNT\system32\odbccr32.dll FileVersion : 3.520.6200.0
C:\WINNT\system32\odbc32.dll FileVersion : 3.520.6307.0
C:\WINNT\system32\odbcint.dll FileVersion : 3.520.6200.0
snmp.pl
FAIL Found C:\PROGRA~1\CSCOpx\campus\bin\CWSNMP.DLL
Although, this has not put any bad impact on the over all functionality of LMS, but i wonder if i am missing any thing because of above mentioned failures. please advise...
jreekers Thu, 10/11/2007 - 08:07
  • Cisco Employee,
Hi Mohsin,
You're running into these bugs:
CSCin46525 : VMS2.2-BT:CMF Self test fails for odbc versions
Release Notes:
The CMF self test produces an error in the odbc.pl part of the test. This occurs because
the test does not have knowledge of the MSDE SP3 ODBC drivers installed by CSA MC. MSDE
SP3 drivers are dated later than those expected by the CMF self test.
and
CSCeb60610 : selftest snmp.pl fails with found
..CSCOpxcampusbincwsnmp.dll
Release Notes:
SNMP Selftest fails with:
snmp.pl
FAIL Found ..\CSCOpx\campus\bin\cwsnmp.dll
workaround:
Temporarily rename ..\CSCOpx\campus\bin\cwsnmp.dll to cwsnmp.dll.orig,
and run the selftest again.
Neither of these limit CiscoWorks in any way. The workaround is to temporarily rename
CSCOpx\campus\bin\cwsnmp.dll to CSCOpx\campus\bin\cwsnmp.dll.orig and run the selftest again.
HTH,
-J
