Call back RAS
Oct 10th, 2007
Dear All,
I have a router Cisco 2610 for remote call, the user authentication dial up to connect network use Tacac.
The user account can already make call back to other router, but not with my Cisco 2610.
every time user dial, he directly connected with no call back.
Could anyone help me to make it work as I want ?
Here is the sotfware image:
IOS (tm) C2600 Software (C2600-IS56I-M), Version 12.0(10), RELEASE SOFTWARE (fc1)
and here is the configuration:
Building configuration...
Current configuration:
ip address-pool local
async-bootp dns-server 10.234.0.29
async-bootp nbns-server 10.234.0.1
chat-script dial "" "ATH1" OK
chat-script callback ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT \T" TIMEOUT 30 CONNECT \c
chat-script offhook "" "ATH1" OK
interface Ethernet0/0
ip address 192.168.20.1 255.255.255.252
ip helper-address 10.144.192.41
ip helper-address 10.144.192.2
no ip directed-broadcast
no ip mroute-cache
interface Async33
description RAS
ip unnumbered Ethernet0/0
ip helper-address 10.144.0.10
ip helper-address 10.134.192.41
encapsulation ppp
async mode interactive
peer default ip address pool RAS
ppp callback accept
ppp authentication pap
interface Async34
description RAS
encapsulation ppp
ppp callback accept
ip local pool RAS 192.168.21.1 192.168.21.10
ip classless
ip route 10.144.0.0 255.255.0.0 192.168.20.2
ip tacacs source-interface Ethernet0/0
tacacs-server host 10.144.0.5 key routerpdn2
snmp-server community Ciscoumum RO 5
snmp-server community Ciscosendiri RW 5
radius-server host 10.144.0.5 auth-port 1645 acct-port 1646
radius-server timeout 20
radius-server key xxx
line con 0
exec-timeout 0 0
password xxx
transport input none
line 33 40
autoselect during-login
autoselect ppp
script connection callback
script modem-off-hook offhook
script callback callback
modem InOut
transport input all
callback forced-wait 5
flowcontrol hardware
line aux 0
exec-timeout 0 0
password xxx
modem InOut
transport input all
line vty 0 4
access-class 100 in
password xxx
Thanks and Best regards,
Coi
stephan.ochs Thu, 10/11/2007 - 00:01
Hi Coi
Just try "ppp callback permit" instead of "ppp callback accept".
sholeh Tue, 10/16/2007 - 18:08
Hi Stephen,
Here are the choises available for the command "PPP callback....."
1. accept Accept a callback request
2. initiate Initiate callback without PPP callback negotiation
3. request Request a callback
Callback permit is not available.
Thank and regards,
Coi
stephan.ochs Tue, 10/16/2007 - 21:35
Sorry
Didn't see you're using IOS 12.0
The command was introduced later...
You wrote that your client can do callback at another router.
Ist it using the same AAA Server?
If not. Are Callback (Dialup client specifies callback number) and TACACS+ PPP settings (PPP IP, PPP Multilink, PPP LCP) the same?
Stephan
sholeh Thu, 10/18/2007 - 00:24
Hi Stephan,
I am using the same AAA server, and tacas+PPP setting PPP IP and PPP LCP.
Coi
