AIR-ANT2506
Oct 11th, 2007
I have installed an access-point 1242 and for arise signal I have installed also antenna AIR-ANT2506 instead of AIR-ANT4941.
Have to I modify some parameter on configuration ?
best regards
Lorezo
Rob Huffman Thu, 10/11/2007 - 05:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Lorenzo,
You probably want to set the Left or Right Primary (I'm not on site right now so I can't see or remember) and take the setting out of Diversity;
Use the antenna configuration interface command to configure the radio receive or transmit antenna settings. Use the no form of this command to reset the receive antenna to defaults.
[no] antenna {receive | transmit} {diversity | left | right}
Syntax Description
receive
Specifies the antenna that the access uses to receive radio signals
transmit
Specifies the antenna that the access uses to transmit radio signals
diversity
Specifies the antenna with the best signal
left
Specifies the left antenna
right
Specifies the right antenna
Defaults
The default antenna configuration is diversity
Examples
This example shows how to specify the right receive antenna option:
AP(config-if)# antenna receive right
This example shows how to set the receive antenna option to defaults:
AP(config-if)# no antenna receive
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_command_reference_chapter09186a0080147d8b.html#2448409
Hope this helps!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
