VG224 buzzing/humming on incoming calls only.
Hi All,
I was hoping I might be able to get some help with the setup of a VG224 that I am doing. It is connected to CCM6 cluster. I can place calls FROM the analog phones connected to the VG224 ports, and it all works properly with two way audio.
When making calls TO the analog lines on the VG224, the calling party simply hears a loud buzzing/humming noise and nothing else. The analog user can hear nothing.
This happens for incoming PSTN calls and calls to other extensions to the VG224 connected devices.
I have not setup a VG224 for incoming calls before, so there is obviously something I have missed. Below is the relevant config parts on the device. Any help is appreciated!
stcapp ccm-group 1
stcapp
voice-port 2/0
ren 3
idle-voltage low
disc_pi_off
input gain 10
output attenuation 10
playout-delay minimum low
cptone AU
timing digit 53
bearer-cap Speech
station-id number XXXXXXXXXX
caller-id enable
sccp local FastEthernet0/0
sccp ccm 10.194.3.10 identifier 20 version 4.1
sccp ccm 10.194.4.10 identifier 10 version 4.1
sccp
sccp ccm group 1
associate ccm 10 priority 1
associate ccm 20 priority 2
switchback method graceful
dial-peer voice XXXXXXXXXX pots
service stcapp
port 2/23
Cheers,
Mark
Overall Rating: 5 (1 ratings)
mark_fox Thu, 01/10/2008 - 12:14
I was wondering if you ever reach a resolution to this issue. I'm running into the same problem.
Hiya,
Yes, it was an IOS bug/problem in the newer IOS releases.
I rolled back to using vg224-i6s-mz.124-2.T5.bin on the suggestion of someone on a mailing list, and this has fixed the problem.
Cisco *may* have fixed it in a later release since Sept 07, but I have not tried. vg224-i6s-mz.124-2.T5.bin works and I have left at at this level as there is no features in newer releases that I need.
philippgrafl Fri, 01/11/2008 - 02:34
I had the same issue this week. I removed the command "caller-id enable", and this resolved it for me.
ahmed-hassan1110 Wed, 04/22/2009 - 11:46
I faced the same problem with IOS version 12.4(9)T7 and solved by the same way by removing the caller-id enable command
thanks philippgrafl
