Martin Ermel Thu, 10/11/2007 - 05:11
  • Blue, 1500 points or more
I attached a document that lists the version numbering of the CiscoWorks applications starting with LMS 2.0 (CiscoWorks 2000) up to the resent LMS 3.0 (...I hope I didn't make a mistake...)
to check the currently installed applications of LMS 2.5 and above, go to Common Services - Software Center - Software Update
there you get a list of all installed apps and their versions
