Prompt for ID on Wrong Password
Oct 11th, 2007
Unity 4.2.1
When a user mistype their password, Unity asks them to enter ID.
I downloaded the latest Advanced Settings Tool and made the change.
Rebooted unity but the problem still occured.
I cannot find the registry location where the change was made, does anyone know where I need to look in the registry?
Overall Rating: 5 (3 ratings)
Rob Huffman Thu, 10/11/2007 - 05:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Majid,
This doen't answer your question but I thought you would want to see the comments on this issue from Unity Design Engineer Jeff Lindborg (for Unity 4.2);
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddb2b9b/0#selected_message
Hope this helps!
Rob
ranpierce Thu, 10/11/2007 - 05:56
  • Silver, 250 points or more
Majid, I know this is the wrong place, long time no talk, email me by clicking in my profile.
rlp
Randy :-)
Christopher McAlpin Thu, 10/11/2007 - 08:29
  • Cisco Employee,
Majid, for Cisco Unity 4.2(1) and 5.0(1)you need an Engineering Special to change the behavior. The business unit is actually testing the engineering specials now and they should be available shortly.
maloumar1234 Fri, 10/12/2007 - 07:57
Thanks a lot. Would you kindly update this thread when the ES is ready?
Best regards
Majid
ranpierce Fri, 10/12/2007 - 10:03
Hey Chris please let me know to, we have a lot of people complain about that here too.
I just live with it.
rlp
Christopher McAlpin Wed, 10/24/2007 - 10:58
  • Cisco Employee,
For Cisco Unity 4.2(1) an Engineering Special is now available.
You will need to open a TAC case and request an ES for CSCsd16651. That fix is currently included in Cisco Unity 4.2(1)_ES127.
An ES for Cisco Unity 5.0(1) should be available shortly.
When invalid password entered at known extension, do not prompt for ID
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsd16651
Christopher McAlpin Fri, 10/26/2007 - 13:47
  • Cisco Employee,
UPDATE!
For Cisco Unity 4.2(1) and Cisco Unity 5.0(1), an Engineering Special is now available.
You will need to open a TAC case and request an ES for CSCsd16651. The fix is currently available in Cisco Unity 4.2(1)_ES127, and Cisco Unity 5.0(1)_ES25.
ranpierce Mon, 10/29/2007 - 06:42
I opened a tac case got the ES and applied it yesterday. It works fine. Thanks Chris.
rlp
Rob Huffman Sat, 10/13/2007 - 07:38
  • Hall of Fame,
    Founding Member
Thanks for weighing in on this issue Christopher. 5 points for your good work here!
Take care,
Rob
maloumar1234 Sat, 11/10/2007 - 22:56
Gentlemen,
I applied the CU421ES127, but was unsuccessful in resolving the issue.
This is the behaviour:
- After applying the ES, we rebooted the server. Then we made sure that Advanced Settings Tool has the right registry key.
- I tested by entering wrong password into a voicemail login and received the failsafe.
- While monitoring the port status, I see it recognize the wrong password, then Unity tries to play a wav file and that is where I get the failsafe.
- If I change the registry setting back to 1, I hear the enter ID instead of password again.
Silly question, will this ES work on a English UK version of Unity instead of US English?
Majid
