PIX/ASA OSPF Route Advertisement
Oct 11th, 2007
My ASA is running OS 7.1.2. Routing is handled by OSPF and static routes. No default or 0.0.0.0 route is defined or learned. I want to add a default route but not advertise it with OSPF. How would I do this? I am was thinking distribute lists but I can't not find this as an option. I then thought about using a route-map but I am not 100% sure how or if it will work.
current config
router ospf 16
network 192.168.198.0 255.255.255.0 area 0
network 192.168.255.0 255.255.255.0 area 0
network x.x.28.0 255.255.255.240 area 0
network x.x.28.16 255.255.255.240 area 0
network x.x.28.60 255.255.255.252 area 0
router-id 192.168.255.12
log-adj-changes
redistribute static subnets
I am thinking about adding
access-list all_other_routes line 1 standard permit any
access-list default_route line 1 standard permit any
route-map static_redist_ospf deny 10
match ip address default_route
route-map static_redist_ospf permit 20
match ip address all_other_routes
router ospf 16
redistribute static route-map redist_ospf
then an all zeros route
Would this work? Other ideas?
Rick
nathancielieska Thu, 10/11/2007 - 08:33
your on the right track, be careful with OSPF on ASA especially with that relatively old version of code. Some people have seen some quirky bugs relating to OSPF and ASA
access-list allowed_statics line 1 ext permit
access-list default_route line 1 ext permit 0.0.0.0 0.0.0.0 any
route-map static_redist_ospf permit 10
match ip address allowed_statics
route-map static_redist_ospf deny 20
In your current proposed configuration your route map will deny any routes from advertising (by matching 10), not only your 0.0.0.0 but all of em.
You might consider moving your static redistribution to a router downstream from your ASA, and just a 0.0.0.0 on the ASA, which you do not redistribute.. something to keep in mind.
