Problem with patching CRS
Oct 11th, 2007
I have CRS 4.5(2) and I'm going to patch it on 4.5(2)SR2.
I have one server and on that server I have BARS installed.
I run restore wizard from BARS. Instalation guide is http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/apps_4_5/english/administ/crs451ig.pdf chapter Patching Cisco CRS.
After all steps seccesfully completed, I have restarted my server.
BUT, when it come up I have massage in Cisco CRS Update Utility popup window:
Please re-initiate the restore from BARS Admin with the same archive file that was used previously in the Patch operation.
I have tried to do this but it stoped on 54% restore procces completed.
What to do now?
How can I patch my CRS?
Please help,
Vlaho
vjemin Wed, 10/17/2007 - 23:02
Yes, I found that. And it works for one my site.
But, for another site, everything was OK, it sais that SR is intalled sucessfully.
And I could login on CRA Administration, but I cann't open script window, and some services doesn't work. I have an error:
Error reading replication status.Error occured while performing reset publisher operation.
com.cisco.database.util.DBException: Failed to reset the publisher subscriber model
com.cisco.database.util.DBException: DBConnection initialization failed due to:initDBConn failed for retry #1/3 due to : [SQLException] (ErrorMsg=Cannot open database requested in login "db_cra_repository". Login fails. SQLState=S1000, SQLErr#=4060) [Nested SQLException](ErrorMsg=Login failed for user "FIMA-IPCC1CRSAdministrator". SQLState=28000, SQLErr#=18456)java.sql.SQLException: Cannot open database requested in login "db_cra_repository". Login fails.initDBConn failed for retry #2/3 due to : [SQLException] (ErrorMsg=Cannot open database requested in login "db_cra_repository". Login fails. SQLState=S1000, SQLErr#=4060) [Nested SQLException](ErrorMsg=Login failed for user "FIMA-IPCC1CRSAdministrator". SQLState=28000, SQLErr#=18456)java.sql.SQLException: Cannot open database requested in login "db_cra_repository". Login fails.initDBConn failed for retry #3/3 due to : [SQLException] (ErrorMsg=Cannot open database requested in login "db_cra_repository". Login fails. SQLState=S1000, SQLErr#=4060) [Nested SQLException](ErrorMsg=Login failed for user "FIMA-IPCC1CRSAdministrator". SQLState=28000, SQLErr#=18456)java.sql.SQLException: Cannot open database requested in login "db_cra_repository". Login fails. Following Exception(s) occured on DBConnection ([[email protected]]url="jdbc:jtds:sqlserver://FIMA-IPCC1:4433/db_cra_repository;instance=CRSSQL;appName=CRSApplication" driver="net.sourceforge.jtds.jdbc.Driver uid="db_cra" ipAddress="FIMA-IPCC1CRSSQL" database="db_cra_repository" authMode="-1" aliasNetworkLib="DBMSSOCN"); nested exception is: java.sql.SQLException: Cannot open database requested in login "db_cra_repository". Login fails., SQLException Details: [SQLException] (ErrorMsg=Cannot open database requested in login "db_cra_repository". Login fails. SQLState=S1000, SQLErr#=4060) [Nested SQLException](ErrorMsg=Login failed for user "FIMA-IPCC1CRSAdministrator". SQLState=28000, SQLErr#=18456)java.sql.SQLException: Cannot open database requested in login "db_cra_repository". Login fails.
