Traffic Shaping
Answered Question
Oct 11th, 2007
i would like to implement a traffic shaping policy that keeps our email traffic from consuming all of our bandwidth on our t-1's. we have a voip phone system in place along with Qos but i still have a few complaints about choppy voice mail and i know email is our number 1 bandwidth consumer so i would like to limit the bandwidth email can use. I don't have any experience with shaping and i am starting with this document - http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800c75d1.html
any other suggestions and or good white papers?
how will i define email traffic?
thanks in advance.
Correct Answer by Pavel Bykov about 9 years 8 months ago
Yeah, you need to remove the old commands first. Forgot to mention that.
Does it work? What is the output of "show policy-map interface" command now?
Overall Rating: 5 (1 ratings)
Pavel Bykov Thu, 10/11/2007 - 13:38
  • Silver, 250 points or more
1. Your QoS policy is BAD. No voice should be choppy under good Voice policy. Maybe you forgot something. Is QoS applied two way? Is there another bottleneck?
2. What is your current QoS policy? Can you post config? You can just add shaper to the class, that has email. After "bandwidth xxx" command just enter "shape average zzz" where zzz is a speed you want to shape it to
3. It really depends on what system you are running for email. Normally it's SMTP, and port number 25. Or you can define IP of your email server as packet SRC/DESTINATION
jerry.mcrae Thu, 10/11/2007 - 14:16
i dont think the QoS is bad b/c TAC looked at it twice i do however have a bottleneck and this is where i want to limit email.
one end:
class-map match-all voice-signaling
match ip dscp af31
class-map match-any voice-traffic
match ip dscp ef
match ip rtp 16384 16383
policy-map EWT_SP
class voice-traffic
priority 1042
class voice-signaling
bandwidth 8
class class-default
fair-queue
the other end:
match ip dscp af31
match ip dscp ef
policy-map EWT_SP
class voice-traffic
priority 1042
bandwidth 8
class class-default
fair-queue
this cmd is configd on each t-1 int - service-policy output EWT_SP
i did notice the class-map config is missing on one end.
NOC#sh policy-map interface Serial4/2:0
Serial4/2:0
Service-policy output: EWT_SP
Class-map: class-default (match-any)
22262925 packets, 8376985095 bytes
5 minute offered rate 7000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/954/0
i think i lost part of my config. i just readded the class-map and i still dont see the class-map config.
EWT_NOC#sh policy-map interface Serial4/2:0
Serial4/2:0
22265315 packets, 8377482618 bytes
5 minute offered rate 13000 bps, drop rate 0 bps
Match: any
Queueing
what's up with that?
Pavel Bykov Thu, 10/11/2007 - 14:34
Ok, see, that's what I meant by "BAD config". This is not right. I can't believe TAC thinks it's OK.
I have more questions then:
1. What is your IOS version? I know this seems silly, but i've experienced a lot of QoS misbehaviour with 12.2 on software platforms.
2. Can you post "show run int Serial4/2:0"?
command "sh policy-map interface Serial4/2:0" is the command that shows the actual performance of your policy. So if it shows what you posted, there is QoS misbehaviour. How many Voice channels are you expecting to run simultaneously? You are allocating an awful lot for a T1...
Ok, here is something to try (it's non-destructive). During my QoS Hi-times, I figured out actual CBWFQ algorithm. Because of that i would suggest a bit different class-default confing. Please try the following:
max-reserved-bandwidth 100
policy-map EWT_SP
class voice-traffic
priority percent 60
bandwidth percent 1
class class-default
bandwidth percent 39
jerry.mcrae Thu, 10/11/2007 - 15:08
1)i ve opened two TAC cases on this. Anyway here is part of the sh ver
c3745-ipvoice-mz.124-3f.bin
2)EWT_NOC#show run int Serial4/2:0
Building configuration...
Current configuration : 305 bytes
description Connected to Cord
bandwidth 1544
ip unnumbered FastEthernet0/0.10
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no cdp enable
ip rtp header-compression
ip rtp compression-connections 64
end
"How many Voice channels are you expecting to run simultaneously?" not sure how many this was designed to support - we use g729 b/t branch offices.
"You are allocating an awful lot for a T1..." i knew this but i thought it was necessary b/c of our vm issues. we were trying to allocate as much bandwidth as possible for voice.
it just happens tonight is maint night so i can give this a go.
thanks.
Pavel Bykov Thu, 10/11/2007 - 15:34
Config is good. Try it and see if the output of the "show policy-map" changes, so it shows up three classes. If it does, than you might expect improvement. You can test it by putting a load in class-default (like ping flood using hping or other load generating utility) and initiate a call.
Also, about the compression - please check the output of "show proc cpu history" command, just in case router experiences a high CPU load. This compression is very gentle on CPU, so just making sure CPU performance is good.
Be sure to post an update after config change.
jerry.mcrae Fri, 10/12/2007 - 07:52
this is what happens when i enter the new config.
EWT_NOC#conf t
Enter configuration commands, one per line. End with CNTL/Z.
EWT_NOC(config)#policy-map EWT_SP
EWT_NOC(config-pmap)#class voice-traffic
EWT_NOC(config-pmap-c)#priority percent 60
EWT_NOC(config-pmap-c)#class voice-signaling
EWT_NOC(config-pmap-c)#bandwidth percent 1
All classes with bandwidth should have consistent units
EWT_NOC(config-pmap-c)#class class-default
EWT_NOC(config-pmap-c)#bandwidth percent 39
deconfigure flow based fair queueing before issuing this command in this class
EWT_NOC(config-pmap-c)#end
and this is the result.
policy-map EWT_SP
class voice-traffic
priority percent 60
bandwidth 8
class class-default
fair-queue
i entered my old config for the moment and it shows in the sh policy-map.
where would i enter the traffic shaping config in the policy-map?
i have a test enviroment to work on your config and see if i can get the router to take the percent cmd's.
thanks again.
jerry
jerry.mcrae Fri, 10/12/2007 - 08:00
i got it - i have to remove the priority cmd's then enter the percent - i was thinking i can overwrite the old config.
Correct Answer
Pavel Bykov Fri, 10/12/2007 - 11:28
jerry.mcrae Thu, 10/18/2007 - 09:49
it appears to be working - i made the config changes this past tuesday night and havent anything from the users which is a good sign. i'll attached the sh policy below. One question since i am giving default traffic 39% do i need to add the traffic shaping policy to kill email above 600K?
Serial0/0
Class-map: voice-traffic (match-any)
411552 packets, 26520411 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: ip dscp ef (46)
194054 packets, 12405888 bytes
30 second rate 0 bps
Match: ip rtp 16384 16383
217498 packets, 14114523 bytes
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 60 (%)
Bandwidth 926 (kbps) Burst 23150 (Bytes)
(pkts matched/bytes matched) 48043/1266560
(total drops/bytes drops) 0/0
Class-map: voice-signaling (match-all)
598 packets, 68652 bytes
Match: ip dscp af31 (26)
Queueing
Output Queue: Conversation 265
Bandwidth 1 (%)
Bandwidth 15 (kbps) Max Threshold 64 (packets)
(pkts matched/bytes matched) 598/68652
(depth/total drops/no-buffer drops) 0/0/0
4886217 packets, 1815368447 bytes
30 second offered rate 63000 bps, drop rate 0 bps
Match: any
Queueing
Output Queue: Conversation 266
Bandwidth 39 (%)
Bandwidth 602 (kbps) Max Threshold 64 (packets)
(pkts matched/bytes matched) 1344169/1260962606
(depth/total drops/no-buffer drops) 0/360/0
jerry.mcrae Thu, 10/18/2007 - 10:10
i noticed some "total drops" in the class default class-map. i would guess it's a good thing.
5393828 packets, 2101973968 bytes
30 second offered rate 143000 bps, drop rate 0 bps
Match: any
Queueing
Bandwidth 39 (%)
(pkts matched/bytes matched) 1688270/1533551526
(depth/total drops/no-buffer drops) 0/3723/0
