Load -Balancing
rafael-molina
I have two switch and 1 portchannel created, this portchannel have associated two interfaces. I need to balance the traffic between the two interfaces.
The configuration is:
Switch 4507R
interface GigabitEthernet3/48 (electrical)
switchport mode trunk
channel-group 4 mode desirable
interface GigabitEthernet5/6 (optical)
Switch 3750G
interface GigabitEthernet1/0/2(Electrical)
interface GigabitEthernet1/0/25 (optical)
Operation Mode:
4507R
EtherChannel Load-Balancing Operational State (dst-mac)
3750G
EtherChannel Load-Balancing Operational State (src-mac)
that option is not balancing, What can I make about this ?
Sorry but my english is no good.
Regards.
paul.matthews
Level 5
Level 5
You need to know a little about your traffic and how a channel works. If you have a single system at each end, with a single IP address and a single MAC address running a single connection, you will not get load balancing.
If you gave a router at each end, carrying lots of traffic for many systems, by default it will not balance, but you can get it to. Similarly, if you have a router one end, and server the other, you may not get the balancing you want.
The options are:
port-channel load-balance ?
dst-ip Dst IP Addr
dst-mac Dst Mac Addr
dst-port Dst TCP/UDP Port
src-dst-ip Src XOR Dst IP Addr
src-dst-mac Src XOR Dst Mac Addr
src-dst-port Src XOR Dst TCP/UDP Port
src-ip Src IP Addr
src-mac Src Mac Addr
src-port Src TCP/UDP Port
Giving lots of options. You need to know what the traffic is to pick the most appropriate.
Paul.
