Jagdeep Gambhir Thu, 10/11/2007 - 14:44
The Certificate Signing Request screen within ACS does not have fields required by public Certificate Authorities. So you need to use following subject format to obtain a proper CSR,
CN=server.domain.com,c=US,S=State,L=City,o=Company,ou=Department
~JG
Please rate helpful posts
Premdeep Banga Sat, 10/13/2007 - 09:38
If you are using 3.3.1 then you'll get issues because of,
CSCef81506 : ACS generates CSR with wrong version number.
Solution is to upgrade to 3.3.3 or 3.3.4
Prem
