VG248 question
Oct 11th, 2007
I have a remote VG248 issue.
I have two ports going to one analog phone (Dual extensions on the phone)
Port 45 -- Shows Link down (Ext 1009)
Port 46 - Ext 1010
when i go into port 45 it shows Call Maager Link down
The event logs show the following
--- Port 45 Registration Failed:Error: DB Config
And when you log into the switch and look at the port status it keeps attempting to register.
My question is, could this be caused by bad wiring?
Also I found a tac case about this and it says something with autp reg. But this has been setup for over a year now.
Rob Huffman Thu, 10/11/2007 - 20:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Don,
I don't think this is a wiring issue either. As you say it shouldn't be an auto registration problem as this would have registered a long time ago. I would look at the VG Gateway config for this port in CCM. Usually when you see an issue that shows DB Config the problem is in CCM.
Hope this helps!
Rob
