Help with AA in Unity
Answered Question
Oct 11th, 2007
Hi!
Is there a way to allow callers to directly enter the extension number while greetings is being played instead of enterring the Last Name
I am using Cisco Unity Connection 1 and call manager 4.
ThankS
Correct Answer by ranpierce about 9 years 3 months ago
yes on the Subscribers > Subscribers > Greetings page in the SA, check the Allow caller input checkbox.
This is checked by default.
rlp
Overall Rating: 5 (1 ratings)
Correct Answer
ranpierce Fri, 10/12/2007 - 05:02
rlp
ivan.ramirez Tue, 10/16/2007 - 18:32
Txs Ranpierce.
I've allowed to input in call handler.But extensions with no voicemail are rejected at prompt. Why ?
ranpierce Wed, 10/17/2007 - 10:42
Sorry for the late reply, I am not sure what you mean by extensions with no voicemail. Do you mean callhandlers? What is the setup exactly and what happens exacty? I can help.
rlp
