CRS Editor in offline mode and custom java classes
Oct 11th, 2007
we often use a few simple custom java classes in our CRS-scripts (e.g. to handle flat ASCII files instead of xml-files)
When connected to the CRS-server, this works like a charm.
But I would like to be able to prepare scripts off-line (at the office instead of at the customer)
Problem is, my existing scripts will not load because it canot find the custom classes we use.
Does anybody know where exactly I should put the custom JAR files on my laptop and/or what config-files I should modify?
Many thanks in advance!
BRuno
hadbou Thu, 10/18/2007 - 06:18
  • Bronze, 100 points or more
Rename ccndir.ini before starting the remote editor. That will actually bring up the editor much faster... You'll just get an error in the log.
