7606 vs 7606-S
Oct 11th, 2007
Can anybody tell me what is the difference between 7606 and 7606-S Router.
Thanks in advance.
Best Regards,
Rahim Amir Ali
As part of the Cisco 7600 Series, the Cisco 7606-S Router is an enhancement on the highly successful 6-slot chassis (Cisco 7606). This enhanced chassis delivers numerous design improvements, including:
? Improved failover mechanisms in the hardware, which when paired with the proper Cisco IOS? Software image, can achieve 100 ms failover
? Ability to deliver higher power of up to 750W per slot
? High-speed fan tray module with 5 speeds on a side-to-side airflow design
? Better thermal flow measurement and management
Please see below
