10-12-2007 12:05 AM - edited 03-03-2019 07:08 PM
Hi all,
Anyone heard what is one arm routing?
Any link show the sample ?
Thx!
10-12-2007 12:09 AM
One arm routing is a router that routes traffic between VLANs. Operates in the old 80/20 rules which means that 80% of the traffic is local to the VLAN and doesn't need routing while 20% of the traffic needs to route between VLANs
It has a single point of failure and most of the time causes bottlenecks/congestion.
Dandy
10-12-2007 05:53 AM
Also known as "routing on stick" is an old method of routing between VLANs in a L2 switch. However, L3 switches has solved this with their mls capabilities. But those who cant afford L3, this is still a reasonable solution.
http://www.cisco.com/en/US/docs/ios/12_1/switch/configuration/guide/xcdvl80q.html
