T.37 on ramp
Oct 12th, 2007
Hallo! I'm trying to configure T.37 on-ramp faxing. My topology is:
incoming fax call->Nortel Meridian Telephone Station->3640 (with FXO interface connected to Nortel)
Here is config:
version 12.4
hostname Router
boot-start-marker
boot system flash:c3640-is-mz.124-17.bin
boot-end-marker
no aaa new-model
memory-size iomem 20
ip cef
ip domain name transas.com
application
service fax_onramp flash:app_faxmail_onramp.2.0.1.3.tcl
fax receive called-subscriber $d$
fax interface-type fax-mail
mta send server mail.admin.com port 25
mta send postmaster [email protected]
mta send mail-from hostname fax.transas.com
mta send mail-from username $d$
controller E1 0/0
interface FastEthernet0/0
duplex auto
speed auto
interface Ethernet1/0
no ip address
shutdown
half-duplex
interface Ethernet1/1
no ip address
shutdown
half-duplex
ip http server
ip forward-protocol nd
control-plane
voice-port 3/0/0
voice-port 3/0/1
voice-port 3/1/0
voice-port 3/1/1
dial-peer voice 1 pots
service fax_onramp
incoming called-number .
direct-inward-dial
port 3/1/1
dial-peer voice 2 mmoip
service fax_on_vfc_onramp_app out-bound
max-conn 1
destination-pattern .
information-type fax
session target mailto:[email protected]
image encoding MH
image resolution fine
line con 0
line aux 0
line vty 0 4
login
end
When i'm trying to call to 3640 FXO number (for example 10015), 3640 doesn't start onramp script, i just hear usual rings.
Please tell me - what i'm doing wrong?
Thnx in advance!
Avner Izhar Fri, 10/19/2007 - 07:39
  • Bronze, 100 points or more
Can you ping your smtp server? I don't see a dns server configured, hence the question.
If it is ping able, try debugging the tcl using 'debug voip application script' and post the results.
HTH, Avner.
