Callmanager 6.0 Database Issue
Oct 12th, 2007
My CCM 6.0 started to display some of the configuration options using the DB Table Field Names instead of original user-friendly format. Has anyone experienced this?
For example:
Inthe region settings;
London TypeBandwidth.BANDWIDTH_1M 384 TypeLossyNetwork.LOSSY_NETWORK_USE_SYSTEM_DEFAULT
Slough TypeBandwidth.BANDWIDTH_729 384 TypeLossyNetwork.LOSSY_NETWORK_USE_SYSTEM_DEFAULT
Warrington TypeBandwidth.BANDWIDTH_729 384 TypeLossyNetwork.LOSSY_NETWORK_USE_SYSTEM_DEFAULT
Also in the Device>Phone settings some field options come as
TypsStatus.STATUS_DEFAULT
TypePhonePersonalization.PHONEPERSONALIZATION_DEFAULT etc.
Y-
j-lehmann Fri, 10/12/2007 - 03:33
this looks like that you use not a english IE. I have the same problem if I use a german IE. After a change to the english one all looks fine.
Best regards Joerg
julien.lefloch Fri, 10/12/2007 - 04:22
Just change the default language used by your web browser to EN-US.
Julien.
