ICM Management Portal
Oct 12th, 2007
I've read the installation guide but I don't know if I need a new server for to install the Management Portal 7.2(1) or I can install it on Admin Workstation, p.e.
Where must/can I install it?
Thank you very much.
Best Regards,
Alberto
Dennis Fogler Tue, 10/16/2007 - 16:16
  • Cisco Employee,
You will need a separate or new server to install the ICM Management Portal. There are two deployment models:
1) Dedicated where all Portal components are installed on a single server.
2) Secure where the application, web & reporting components are installed on one server and the provisioning & database components are installed on a second server.
karthikayyappan10 Wed, 11/24/2010 - 22:32
While Installing Management Portal Application Server Component. I'm facing one error. I cannot proceed further.
"Adjusting file\folder permission failed, required application C:\WINDOWS\System32\calcs.exe could not be found"
Database Server component Installed successfully.
Can any one help me to resolve the error.
Take a look at the attached screen shot.
Karthik
