Stack Switch Cat3750
Oct 12th, 2007
I have stack switches, both are Cat3750. After I stacked it, I have the following error:
Switch# Role Mac Address Priority State
1 Slave 0000.0000.0000 0 Provisioned
*2 Master 0014.a871.4100 14 Ready
Can I know why?
Overall Rating: 1 (1 ratings)
It looks as though even though the other switch in your stack is provisioned within the config, the stack cannot see it correctly (Hence no MAC address). This way be due to the stackwise cable not being correctly connected or an SDM or version mismatch between the switches. Can you take a look at the log on the switch to see if it tried to be added to the stack, but couldn't due to an issue, or if the stack doesn't show any indication that an additional switch tried to be added?
Martin
mycla9_123 Fri, 10/12/2007 - 07:44
After issued the command, " boot auto-copy-sw". The "provision" message appeared!!
Before, I issued the command, the status was "version mismatch"
