Error message on ASA5520
Oct 12th, 2007
I am unable to find documents on CCO that explains error messages on ASA5520. "%ASA-2-106001: Inbound TCP connection denied from x.x.x.x/1266 to x.x.x.x/22 flags SYN on interface outside" registered on ASA5520 7.2(2)22. Does anyone know what this means and how can I resolve this problem? I would like to allow port 22 and 23 to certain destination devices. Thank you.
whisperwind Fri, 10/12/2007 - 05:57
Means the traffic was denied because there is no ACL entry to permit, the ASA is working as designed. If you wisht o allow it then add the ACL entry for the port 22/23 that you wish to be accessed.
santipongv Mon, 10/15/2007 - 04:17
I figured out that the problem was not with the ACL but with a route statement. Once I removed that route statement, I am able to connect to the device successfully. Thank you.
