Extension Mobility
vinothdhanapal
I had altered the parameters for extension mobility so that auto logout is true and max login time is 10:00 hours. But still the users say that it does not automatically logout ... and they see that they are logged in the morning ...
Is there any services that I need to restart ?
Your help is much appreciated.
Vino
Hi Vino,
If you can do it with the users logged out and perhaps during an after hours maintenance window try that. I would hate to see this cause any issues. I don't think there would be any problems but.... better safe than sorry :)
Hope this helps!
Rob
9 Replies 9
AJAZ NAWAZ
Level 5
Level 5
Hi Vino,
<http://www.cisco.com/univercd/cc/td/doc/product/voice/vpdd/cdd/4_1/4_1_2/mobility/emapich1.pdf>
The Logout Scheduler in the Login Service times all login occurrences if you have
specified a system maximum login time. If you have not set the login duration, the
automatic logout period for that device defaults to the system maximum time.
Furthermore, can you confirm the user device profile is set with extension mobility logout?
bye for now,
Ajaz
Ajaz
I had set the extension mobility logout for each device... also specified the max login time in the service parameter...
Do i need to enable extension mobility service in all the callmanagers in the cluster or only in the particular subscriber you want extension mobility? ( Also do we need to enable it on the publisher as well ?)
Vino
Vino,
AFAIK Whenever you configure or make changes to CCM, whether you are logged into a sub or pub, the changes are actually carried out on the pub. If the pub is not available - you will be unable to make any changes until the pub returns back online.
All changes made to the pub are then replicated to all subs. I know it's unrelated to the original question but nonetheless very important to know this.
So, back to the original issue. Please confirm that 'Enforce Maximum Login Time* ' is set to true?
Ajaz
Enforce Maximum Login Time is set to true...
Vino
Rob Huffman
Hi Vino,
I don't think that the Auto Logout will be applied to phones that were already logged in when this change was configured. You can try two things.
1. Ask users to logout at the end of the day and the next time they Login this Auto Logout 10:00 Hours will work.
2. Try a Cisco Tomcat Service restart.
Hope this helps!
Rob
Rob
Shall do that ... do I need to restart the tomcat service while the users logged in or when they logout?
Vino
Hi Vino,
Hope this helps!
Rob
Rob
I tried it restarting tomcat service with users logged in as the users are our customers and could not ask everyone... I haven't heard about any issues after that.. So I believe it should be resolved.
Many thanks for your help and I rate it 5
Vino
Hi Vino,
First off you are most welcome :) Thanks for posting back with your results, I have rated your post a 5 for following up to help others who may face this same question.
Thanks again and take care,
Rob
