Consoling & SSHing memory problem on 3750G
Oct 12th, 2007
I have a switch in production. Its a 48 port 3750G PoE. I need to access it and modify the config.
When I am consoling in, I get the error "INSUFFICIENT MEMORY, TRY AGAIN LATER"
When I am SSHing, it says "OPERATION TIMED OUT"
When using DFM, it gives me alert "INSUFFICIENTFREEMEMORY"
The switch is working fine otherwise. I don't want to reboot it.
Telnet is disabled on the switch.
Is there a way to fix this and prevent this from happenening in future.
Overall Rating: 3 (1 ratings)
darrenj Fri, 10/12/2007 - 10:29
This is something that I've not seen or heard of before. What happens to pings to the switch - do they time out or are they slow?
There is only one time I've struggled with a console session to a router and it is when there was a big broadcast storm. Even then, I could get to the console, only the output was slow.
Unfortunately, you may need to reboot the switch but I would do so with a console connected to it to see what it tells you. Other than that, open a case with Cisco :-(
Sorry I can't help any more
Dazzler
mzsaad123 Mon, 10/15/2007 - 06:45
Pings are fine. They aren't slow.
All switch functionalities are fine (including L3 fucntionality). The only problem is accessing through console or SSH (telnet is already blokced)
