forword a call to a autoattendant script?
Oct 12th, 2007
The secretary answer the phone and she has 4 lines on her phone. If she is busy on line 1, the call will will go the line 2 ,line 3 until the line 4 will call the 304(autoattendant).
But il will like that able to use the that setup but able to transfer to the 304(autoattendant) on line 4 when the office is close
But i am trying to know with command
My config
ephone-dn 33 dual-line
number 150
label 842-7672 Ligne 1
call-forward busy 151
call-forward noan 153 timeout 10
corlist incoming inter
huntstop channel
ephone-dn 34 dual-line
number 151
label Ligne 2
call-forward busy 152
call-forward noan 153 timeout 7
huntstop channel
ephone-dn 35 dual-line
number 152
label Ligne 3
call-forward busy 153
huntstop channel
ephone-dn 36 dual-line
number 153
label Ligne 4
call-forward busy 300
call-forward noan 304 timeout 3
huntstop channel
Rob Huffman Fri, 10/12/2007 - 07:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Dominique,
I may have misunderstood question but couldn't you use the CallForward All softkey to forward calls that come into DN 150 (Line 1) to 304 after hours. This would basically take the other 4 lines out of the equation and take after hours calls straight to the AA at 304.
Hope this helps!
Rob
dcoulanges Fri, 10/12/2007 - 07:50
Thanks for response,
1. Right now the secreatary use CallForward All softkey to forward calls manually, i am trying to do it automatilly to 304 thats come to DN 150(line 1) if no answer during the day.
Rob Huffman Fri, 10/12/2007 - 08:10
  • Hall of Fame,
    Founding Member
Hi Dominique,
Can you try;
number 150
call-forward noan 304 timeout 10
huntstop channel
Hope this helps!
Rob
