Error Command is disabled - from lwapp CLI
Oct 12th, 2007
  • Bronze, 100 points or more
i keep getting this message when trying to restore back to default or clear controller ip definations in the lwapp ap. How do i get around this?
ankbhasi Fri, 10/12/2007 - 09:33
  • Cisco Employee,
Hi Friend,
East way is let it join controller first and then you can reset the configuration of AP from controller GUI.
If that is not possible for you for any reason you can console into AP and issue a command "dir flash" and you will see 2 files name "env_vars" and "private" name file. Delete it from flash running a command "delete flash:env_vars" and same command to delete second file and just reload the AP and it will delete old configuration regarding controller ip address.
Ankur
*Pls rate all helpfull post
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
