Router's IP Address/Connect to Router
Oct 12th, 2007
As you may notice by my conversation title, I'm a complete newbie to Cisco. All I really need to know is how can I determine the IP address for my 2600 series Router? I have no idea how to communicate with it. I'm not familiar with any software related GUI's for configurations (if any exists).
Any help would be much appreciated.
jreekers Fri, 10/12/2007 - 09:15
Do you know the hostname for it?
Do you have physical access to it?
Morbo7000 Fri, 10/12/2007 - 20:24
I don't have the hostname either. I do however have access to it.
I read about connecting to it via a com serial port, and then hyperterminal to it, but the device only has RJ(45?) input/outputs. I'm guessing I'll end up telnet to it, but without an IP or hostname, it's kinda difficult, right?
I thought about using 'ping -a 192.168.1.x' and just repeating that for the last octect until I saw a hostname that might resemble the router, but that hasn't worked yet.
