PIX will not accept ACL
acameron12
From a console connection with the interface configuration:
name 172.16.204.198 pix_manage
name 172.16.204.200 fo_pix_manage
interface Ethernet2
speed 10
duplex full
nameif manage
security-level 80
ip address pix_manage 255.255.255.224 standby fo_pix_manage
I am attempting to add the following ACL in order connect to the switch and manage it remotely. At least from a device in the same subnet as the interface indicated
access-list uni_manage extended permit tcp 172.16.204.192 255.255.255.224 172.16.204.192 255.255.255.224 eq 22
I am receiving the following error message:
ERROR: IP address,mask <pix_manage,255.255.255.224> doesn't pair
Where in these steps have I erred?
14 Replies 14
acomiskey
Level 10
Level 10
Does it take something like this...
telnet 172.16.204.192 255.255.255.224 manage
That did, thanks for your prompt and helpful response.
Does the PIX support https or ssh access?
Yes it does. Sorry I should have put...
ssh 172.16.204.192 255.255.255.224 manage
http server enable
http 172.16.204.192 255.255.255.224 manage
Please rate helpful posts.
So much better, however, I am now getting authorization problems. Although I am able to access the PIX on my console and telnet access. The ssh and https access will not accept the credentials I setup for telnet.
Do I need to specify a different username and password conbination for ssh & https as opposed to the console & telnet access?
Thanks again.
Want to post a clean config from the pix?
Sure, see atached.
Thanks for your help so far.
I think this will do it...
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
username cisco password cisco123
Getting closer.
My ssh2 access works now.
When I try https access I get a pop-up
prompting for username and password which
I enter. I then get
HTTP 404 - File not found
I tried these commands:
http server enable
http 172.16.204.214 255.255.255.255 manage
But, I am still getting the error 404 page not found message.
Well...1 out of 2 isn't bad. Are you sure the PDM is installed on the pix?
1 out 2 is not bad at all.
I do not know that PDM is installed.
How do I determine that?
I obtained a version of the PDM object, but, the instructions I have located do show where to tftp the object to on the VPN server. Is this a simple tftp to the flash: location?
Sorry in pix 7 it is the ASDM.
http://cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804708d8.shtml#t8
You could look at show ver or dir flash: to see if it is installed. If not the doc above will help you get it installed.
Thanks for all your help.
My privilages do not permit downloading the ASDM object.
But, I progressed further than I was earlier today and I learned a couple of new things.
