If I purchase a LWAPP AP can I migrate it to non LWAPP
Oct 12th, 2007
If I purchase a LWAPP AP can I migrate it to non LWAPP. If I purchase a non LWAPP AP can I migrate it to LWAPP, and then back to non LWAPP. Are there any advantages to buying a native LWAPP AP
ankbhasi Fri, 10/12/2007 - 10:01
Hi Friend,
Yes it is possible to convert LWAPP to IOS AP and also from IOS to LWAPP APs.
Even if you buy non lwapp ap you can convert it to LWAPP and again back to non LWAPP.
From NON LWAPP to LWAPP
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html
From LWAPP to NON LWAPP
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp161272
Also the only advantage of buying a native lwapp ap is if your wireless network is only controller based then you do not need to go through all procedure of converting your APs from NON LWAPP to LWAPP and you can start using it directly.
Ankur
*Pls rate all helpfull post
ankbhasi Fri, 10/12/2007 - 10:10
Hi Friend,
Please mark this thread as resolved so other can benefit for it.
Ankur
