Edison Ortiz Fri, 10/12/2007 - 10:33
  • Hall of Fame,
    Founding Member
Yes, it does.
eapenteng Tue, 10/23/2007 - 11:10
Ed, thanks for your response, but here is an issue:
1. When IOS - s72033-ipservices_wan-mz.122-18.SXF10 - was loaded, SSH would not work when configured.
2. The IOS was upgraded to - s72033-ipservicesk9-vz.122-18.SXF10a - which took down the ATM CARD/Ehanced FlexWan/WS-X6582-2PA.
3. The 2nd step, above, was reversed and the switch was reloaded with - IOS s72033-ipservicesk9-vz.122-18.SXF10, which brought up the ATM CARD/Ehanced FlexWan/WS-X6582-2PA in slot 3.
Please, what may be the glitch here?
The next plan of action is to upload - s72033-entservicesk9_wan-mz.12.2-18.SXF10.
Will this enterprise pack support ssh and the flaxwan? Our research shows it does but
it is not working.
Thanks for your assistance.
Edison Ortiz Tue, 10/23/2007 - 14:25
  • Hall of Fame,
    Founding Member
A quick search didn't yield any response as to why WS-X6582-2PA is not working under SXF10.
Very strange.
Yes, the enterprise feature set brings everything and if it doesn't work, I suggest opening a TAC on this problem.
I also suggest being careful when going from modular to non-modular releases. Stick with one type of release.
Edison Ortiz Tue, 10/23/2007 - 17:29
  • Hall of Fame,
    Founding Member
Glen brought up a very good point which I failed to notice on my first reading.
First image mentioned in your 2nd reply did not contain k9 so it did not support SSH.
Try downloading the same image release but with k9 on it. The first image was non-modular so it should support the FlexWAN module.
glen.grant Tue, 10/23/2007 - 14:07
  • Purple, 4500 points or more
If you look at the imagename if it has a "k9" which yours does it supports SSH , your other image does not have k9 in it so it does not support SSH .
