ASA5505 VPN Remote Access
Oct 12th, 2007
hello,
I'm having problems setting up an ASA5505 VPN Remote Access with Cisco VPN Client 5.01.0600. ASA5505 is 7.2 Software with K9. I get this message in the log: Group = Test, IP = x.x.x.x, Removing peer from peer table failed, no match! I set up a test IKE policy that uses 3des/md5, DH group 5, and preshare. The test group policy uses IPSec as the tunneling protocol. Any hints would be great. thank you
amritpatek Thu, 10/18/2007 - 14:10
  • Silver, 250 points or more
If you are facing authentication problem check if you have configured the commands "authentication-server-group" and "default-group-policy". Also make sure that Split tunnel and relevant access-lists are configured properly. Following link may help you
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008046f307.shtml
