No switch Management under CAM ver 4.1.2.1
Oct 12th, 2007
I don't see any Switch Management option under CAM 4.1.2.1. I have only following -
Device Management
User Management
Monitoring
Administration
Any idea why ?
tstanik Thu, 10/18/2007 - 14:12
The CAM maybe not able to detect any switches in your setup and so you are not getting the switch management option. If you are using CAM across a firewall to access switches you will need to setup the firewall to allow the access.
