Has any one work with Innerwireless using Cisco LWAPP solution
Oct 12th, 2007
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I was wondering if anyone has worked with Innerwireless with Cisco LWAPP solution. I want to know if there are any drawback to using innerwireless instead of the normal AP design. Critical applications will be used on this wireless system which will be installed in a hospital.
Let me know what you think... never worked with Innerwireless and there is no doc on Cisco's site on design of any configuration guide.
Thanks!
Overall Rating: 5 (1 ratings)
dennischolmes Tue, 10/16/2007 - 06:54
  • Gold, 750 points or more
HUGE ISSUES!!!!! RFID and location services are out the door if you use innerwireless as the leaky coax is only seen as one big wonkin antenna. The only supported DAS at this time that I know of is from Mobile Access. The only advantage Mobile Access gives you over traditional antenna configurations is the ability to multiplex cell phone, pager, and other similar signals throughout the entire array using one set of antennae.
Scott Fella Tue, 10/16/2007 - 19:27
  • Hall of Fame,
    2017 Wireless
I hear you but my client has purchased a whole bunch of Cisco gear (LWAPP) and decided to use Interwireless since they have partnered with Cisco as stated on some of their install history. The funny part is that it also includes location and voice. I was hoping someone would post some positive stuff, but I guess not. Thanks!
dennischolmes Wed, 10/17/2007 - 03:29
Sorry. There is no real upside here. Innerwireless will support voice as the entire floor of a building can be covered with one AP but you can not do location services unless you install a location services sensor, a third party ckoke point, or are willing to accept closest AP, which unfortunately is the whole floor. Yes, they partnered with Cisco, but who wouldn't. Again, sorry for the bad news.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
