paolo bevilacqua Sat, 10/13/2007 - 03:19
  • Hall of Fame,
    Founding Member
Yes. Use a router for this task. Under the serial interface, configure a service-policy.
Then you will have class-map that will define QoS for different BO using ACLs.
The specifics depends on what exactly you want to do, if you have voice, etc.
